Journey begins! After 4 teeth out/braces same day... Day 6!
Timetoshine
#1 Post by Timetoshine »
Here are my teeth pre and immediately post bracing/extraction (will post in next post as they need to be smaller size for posting!) crazy angled teeth- miserable looking at the twisted wire, but confirmed how much I needs braces I guess!
Decided to have both bracing and extraction on same day to cut down on the number of sore days- weird sort of logic I know! All went well, albeit the seemingly normal soft foods, 3kg weight loss, and popping painkillers! Today is day 6 and I sooo can't wait to see progress. My partner told me to stop checking ;)
Called in to ask ortho for more wax yesterday,and hv been using teething gel on my gums!
Haven't chewed anything since I had them on- I chop food up into tiny pieces, back of mouth and swallow. Teeth are quite tender, but ortho did say there would be a lot of movement in first months as extraction will allow for it.
In ovation clear on top 6 + 2 metal
Metal on lower 8
Metal spring on lower, and the wayward tooth is bracketed but not in archwire.
Have been told 16-20 months.
Molar bands in future to close 2nd bicuspid extraction sites. BTW- extractions are why I'd put off ortho treatment for 15 yrs- was nothing to worry about and highly necessary I can understand that now!
Right- time to visualize some movement in the hope it makes them move! Have just seen someone's pics of canines dropping down to look less fang like- yay!!
Anyone know what Torque Auxillary Devices are?
Timetoshine
Re: Journey begins! After 4 teeth out/braces same day... Day
#2 Post by Timetoshine »
Here are the pics. I note how closed my mouth is in the braces shot - post-extraction your mouth wants to stay closed and just drool :crazy:
Timetoshine
#3 Post by Timetoshine »
Here is the braces shot...
NeilH
#4 Post by NeilH »
Hi, good luck. Looking forward to hearing how you get on.
Timetoshine
#5 Post by Timetoshine »
Thanks NeilH - posted those pics up because there has to be some major changes going on during my treatment to get these aligned!
Tobilei
#6 Post by Tobilei »
Welcome to the board and good luck :)
I remember when I first got them on and would check my teeth daily. Now I really only check for a couple of days after adjustments and if something feels like it's moved or moving (or I notice something while checking for random food particles :? ). Things will move! :)
rhibee83
#7 Post by rhibee83 »
You have really nice white teeth and they will look amazing once you are done :) you should be excited :) :thumbsup:
Timetoshine
#8 Post by Timetoshine »
Thanks - I am excited... every mm counts!
I have new respect for people who have had / have braces after the last week - ouch! But all worth it.
joeyyeo
#9 Post by joeyyeo »
Looking good! I extracted 4 teeth too but I definitely did not do everything on the same day, wow you are brave. Your teeth will definitely look beautiful when you are done! :D
Upper braces off after 636 days!
Ciara
#10 Post by Ciara »
Very brave to have extractions and braces applied on the same day. Good luck with the rest of you treatment.
tiana
#11 Post by tiana »
Hi. How do you felt during the extraction? Did it hurt?
I have a teeth to be pulled off and, like you, i wish to have braces putted in at the same time. I hope this is possible.
SunshineRay
#12 Post by SunshineRay »
I have to have 2 teeth out and I wish they would do it all on the same day. Congrats on starting your journey!
Bikerchick85
#13 Post by Bikerchick85 »
Congrats on getting braced! :) I also had 4 extractions and also have the in-ovation clears on upper arch and metal in-ovation on lowers! You can see my progress in the stories section. It's amazing how fast they move after getting those teeth out! You already have beautiful teeth and your results will be amazing! Looking forward to seeing your progress! I didn't get my braces the same day though. You are very brave! I got mine on about 3 weeks after the extractions. I know some people don't find extractions to be a big deal but I was pretty sore after mine. I have a very high tolerance for any kind of pain other than any mouth-related pain. But I'm so glad I did it and can't wait to see the final result!
*Est. Sentence-24 months*
thisgal201
#14 Post by thisgal201 »
Congrats on your braces!! :jump: It will be amazing when you look back at those first pics and see how much you progress :)
BracesChick
#15 Post by BracesChick »
