In Ovation C New Patient :D
Got my braces on last week, will have 4 extractions next week, here's how my teeth are at the moment, I will keep this updated for future reference nostalgia purposes ^^ If you have any questions feel free to ask.
Braces type: In-Ovation C, ceramic brackets top and bottom
Sentence: 24 months
Sentence: 24 months
http://www.archwired.com/phpbb2/viewtop ... 13&t=46203
In Ovation-C Braces
Braced on Dec 2013 for 24 Months
- mapleleafman888
Re: In Ovation C New Patient :D
Congrats on getting your braces, how do those brackets feel? One ortho I went to used them, but I opted for damons.
My story:http://www.archwired.com/phpbb2/viewtop ... =9&t=45354
Upper and Lower Damon Braces for 18 months!
I met 46 braceface adults when I had braces myself!
For the first few days I thought they were rough on the lips. At one point I thought one of the brackets had chipped since it felt super rough. But after a few more days it's not that bad, I no longer need dental wax.
In Ovation-C Braces
my teeth are more crowed than yours. so now i feel much calm to get 4 extractions. i am going to start it soon.
they look really good! good luck on your braces journey!
Thank you still a long way to go though =]
In Ovation-C Braces
First Adjustment- Square Wire + Extractions (4)
In Ovation-C Braces
i did not see wire cross your gaps? Mine is connected.
Next adjustment in February they will put the brackets on the molars (I had to do some fillings first
In Ovation-C Braces
I like the looks of your braces. I will be getting the In Ovations myself but just the 6 top ones that show in ceramic. The rest will be metal but that's because my bite is really off so the metal will be stronger for that. I am told I will be in mine for 30 months. It was nice to hear that it didn't take long before you got used to them.
07/14/14 - 4 spacers put in
07/25/14 - braces top and bottom put in minus 2 molar bands that they couldn't fit
9/11/14 - 2 spacers put in between the bottom back molars
9/19/14 - last 2 bottom molar bands in and all hooked up, new wire, started elastics too
10/14/14 - new square wire change and thick elastics
04/24/17 - braces removed!!!
Good luck with your treatment! I think your teeth look beautiful already!
15 mos update, gaps are almost completely gone
Bottom braces changed to metal due to my teeth touching the ceramic brackets (did not want to risk tooth chipping).
In Ovation-C Braces
Your teeth look fantastic!
Braces installed October 2, 2014
Braces removed May 17, 2016
