It is currently Sun May 19, 2013 2:47 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Canker cover (not just for canker sores)
PostPosted: Tue Mar 01, 2011 3:23 pm
Offline
I went to my dentist today for tmj check in.
I had burned my gums bad over the weekend, as in I had huge red holes. I asked him if it would heal ok. He gave me a sample of canker cover for the pain and to aid in healing.
These are awesome. It's lasted hours (still going) and makes a Minty gel shield which protects the area. I could see it having many uses(especially for braces cuts/sores?)
He said they should be available at cvs and rite aide.
Top
 Profile
 Post subject: Re: Canker cover (not just for canker sores)
PostPosted: Tue Mar 01, 2011 4:04 pm
Offline
Can you state the product?
_________________
Top
 Profile
PostPosted: Wed Mar 02, 2011 7:35 am
Offline
It's actual name is "Canker Cover"
The sample pack only had 1 cover, not sure how many are in a purchased product.
They also have a website cankercover.com
Top
 Profile
PostPosted: Wed Mar 02, 2011 10:40 am
Offline
Ahh, thanks!
_________________
Top
 Profile
PostPosted: Wed Mar 09, 2011 4:31 am
Offline
LOVE these things! I can't recommend them enough, they are worth their weight in gold. Not only does it treat the sore, it provides a barrier to keep the sore from continually getting rubbed by the offending bracket, or in my case, TAD.
Top
 Profile
PostPosted: Wed Mar 09, 2011 9:04 am
Offline
would they work to protect again brackets/wires at the very back of the mouth, i am in AGONY....i got larger wires placed and also brackets on my last teeth (back 4) on monday and i feel like i'm going to die....i have such bad lacerations in my checks top and bottom i'm in complete desperation.......HELP, this makes the first week of braces seem like a romp in the park imho
_________________
--Grillz
http://www.TickerFactory.com/
for my saga, click below
http://archwired.com/phpbb2/viewtopic.php?f=9&t=38112
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
