It is currently Sat May 25, 2013 1:50 pm
Post new topic Reply to topic  [ 134 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Author Message
 Post subject: Re: Lau's Story
PostPosted: Thu Apr 19, 2012 4:08 am
Offline
Let's see some pictures Lau! I am curious to see what wires for rotating and tilting look like as they are probably in my future.
I hope your pain has subsided.
Best wishes
Jem
_________________
. Now at 16 months
Click here for my story viewtopic.php?f=9&t=42194
Top
 Profile
PostPosted: Thu Apr 19, 2012 5:13 pm
Offline
hey- here is a pic that i took with my cel phone. the best way i can explain is that they took my flexible (original) wire and they put it behind my thicker archwire and they tightened and tightened. I think they'll keep doing this for while until my teeth straighten. I had read somewhere that your teeth will follow the flexible wire and that the thicker one is to maintain your bite/open arch. Good news is i have no pain anymore-
PD: check out my metallic silver ligs- they ran out of the light gray ones :roll:
_________________
Wore Top & Bottom traditional metal brackets, wore elastics both sides 24/7
Brace day: Oct 4 2011 / Sentence: 18 months - DONE in 16 months
My story + progress pix
Top
 Profile
PostPosted: Thu Apr 19, 2012 11:50 pm
Offline
I love the double wires - it must feel like they're working twice as hard!
_________________
1st Feb 2012 - extraction both upper 2nd premolars
Braced 9th March 2012 - lower metal fixed and upper removable plate
5th September 2012 - bite plate gone, upper ceramic fixed fitted
Estimated treatment time 18-24 months
Top
 Profile
PostPosted: Fri Apr 20, 2012 1:03 pm
Offline
Psychologically yes, it feels like I am Super Brace girl here, and hoping that it straightens my teeth FAST!! I havent noticed big change for a while so i need at least something to move :-*
_________________
Top
 Profile
PostPosted: Sat Apr 28, 2012 6:03 am
Offline
Hi Lau,
I was curious how is your midline movement going along? Any progress so far?
_________________
Full METAL. Sentence: 17-21 months.
Top
 Profile
PostPosted: Mon Apr 30, 2012 1:08 pm
Offline
Hey Archwired28!
my midline is looking a lot less crooked for sure. I'll be posting a progress picture on the 4th which will mark my 7th month monthniverssary.
Since i opted for not extracting any teeth (for a perfect smile ortho recommended taking out 3 teeth) I will not be going for a Hollywood smile, but rather a major improvement- which I am perfectly comfortable and happy with.
Thanks for checking in!
_________________
Top
 Profile
PostPosted: Thu May 03, 2012 7:29 pm
Offline
Happy 7th Month-niverssary to me!! here are my progress pics.
its been 20 days since they added flexible wires to my teeth to rotate them. I don't see a lot of change so i will ask them on my adjustment on the 14th.
_________________
Top
 Profile
PostPosted: Thu May 03, 2012 8:41 pm
Offline
Looks like you are coming along nicely!! I am excited about starting my journey!
_________________
~KIMMIE
Click here to view my story: viewtopic.php?f=9&t=42578
Top
 Profile
PostPosted: Fri May 04, 2012 6:35 am
Offline
Looking good :D
_________________
My Braces Story
Top
 Profile
PostPosted: Fri May 04, 2012 1:46 pm
Offline
Thanks NICURN85 and CleoAZ for accompanying my journey and the kind words!
_________________
Top
 Profile
PostPosted: Mon May 14, 2012 9:21 am
Offline
Had an adjustment today! :pinkbraces: and the filling of a cavity :GapToothed:
Everything looks good he said. he tightened and replaced my ligs. I need to go back in 6 weeks (not 4)
I asked him about the position of the teeth and he said they are pretty much as they will be. I do still have the 4 mm asymmetric midline, but I will be done in 4 months. If i want to do IPR, it will be about approx 8-10 months, so I went ahead and confirmed I want to keep going as scheduled. Straight teeth and a little asymmetry will be Ok for me.
_________________
Top
 Profile
PostPosted: Tue May 15, 2012 8:43 am
Offline
Hello Lau,
14 May was also adjustment day for me. I am also back in 6 weeks (plus 2 days as I am elsewhere on the Monday)
Thicker wire plus small powerchain this time. I think my left canine is starting to de-rotate and hopefully this thicker wire will complete that. The left canine and lateral are competing for space at the moment and hopefully that will also resolve somewhat over the next 6 weeks.
All the best,
Jem
_________________
. Now at 16 months
Top
 Profile
PostPosted: Tue May 15, 2012 10:14 am
Offline
Hi Jem! glad you're doing well. another coincidence - I will go to the next adjustment on June 21 as from the 25th i will be out on vacation for 2 weeks.
how's your journey treating you?
_________________
Top
 Profile
PostPosted: Tue May 15, 2012 5:15 pm
Offline
Hey Lau! May 14 must have been adjustment day all over!! I had my adjustment too!
It only lasted about 15 mins., and they activated the other side of my Forsus, and moved it back a tooth. Moving it back has made ALL the difference! I could do this the rest of the time instead of elastics now. Finally, it is fully comfortable. The only drawback is that so much food gets caught in it...
Wow, Lau--are you getting your braces off before even 1 year??? You are sooooo lucky!!
I still have a year to go!
Hey my next adjustment is June 18--5 weeks from yesterday. It will be the shortest time between adjustments that I have had so far. It was 9 weeks between adjustments this last time...
Your teeth are so white Lau, and I am so jealous!! :HugeGrin:
_________________
Top
 Profile
PostPosted: Wed May 16, 2012 6:25 am
Offline
Hi Klo!
awesome to hear you and your friend Mr forsus are doing well! :thumbsup:
Thanks about the compliment of my teeth being white. After I got the cavity filled i feel I am not doing enough to clean my teeth. I hadn't had one in many years, so i felt like I need to waterpik more.
About my treatment, I am hoping to get these babies off at 12 months rather than 18 but I am taking the 'express' solution without centering my midline. I thought about it and still stand behind my original objective which was to improve my smile as fast and cheap as possible. My main goal was fixing a tooth that had tilted & behind the rest and that has been fixed as well as my bottom teeth which were very crooked. I am going to try to pull a "Tom Cruise" smile (not as charming plus I am a girl) LOL :mrgreen:
Take care,
Lau
_________________
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Duendecilla, melanie and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
