Month 1 - Pictures[All pictures are flipped around to be true to life]
My teeth in their entirity from a front on angle. The teeth on the left hand side have moved more than the teeth on the right hand side.
My front top teeth from a different angle. I'm pleased with the progress of the left teeth. The front left tooth has been brought more inward and the tooth next to that on the left appears to have aligned with the larger one next to it. The right hand teeth have changed but have not made as much of a drastic improvement.
My bottom teeth. The two on the left have definitley aligned with one another and the very front left one has come forward slightly. The tooth next to the very front one on the right has begun to align with the rest of my mouth but the very front right tooth does not appear to have moved any. I'm hoping that it's merely a case of that one being the last to move.
This is a week 3 and 1 month comparison. My teeth look better from the side now.
This is what my profile looks like without the aligners in (top picture) and with the aligner in (bottom picture). As you can see, they cause my top lip to protrude a significant amount.
This is what my top aligner (top picture) and bottom aligner (bottom picture) looks like when out of my mouth. You can see the clear plastic moulds of my teeth on the top aligner and the plastic part that goes over your gum on the bottom aligner (that doesn't fit me properly).
WOW They're looking AMAZING!!! Thanks for shpwing us the aligner I was curious as to what it looked it. Looks neat.
