As I got into the college years, peers in braces were fairly few and far between, but I'd occasionally consider doing braces - as I had started to become unhappy with some aspects of my teeth/smile. I'd always make up an excuse why I shouldn't do it then, and talk myself out of it.
More recently, I've realized that it's something that I've wanted to do for 15 years, and there was really no reason not to do it. Sure it'll be a hassle, but it's a short period of time in the grand scheme of things. I kept thinking - 'If I had done this at 25, I would've been done years ago'. So finally, after a mention from my general dentist in May '12 that some of my teeth seemed to be shifting, I made an appointment for a consult and decided in my mind that I would go through with the recommendations as long as I found an ortho I liked.
So here I am, about 6 weeks later and a few weeks past my 32nd birthday and my top braces went on today. I need one pre-molar extracted, and then will have braces for 16-18 months. First 6 months will be top braces only, with a lower lingual holding arch, and then lower braces will be added later. Turns out my teeth/bite were worse than I had ever been told - and my current ortho thinks that I definitely could've benefited from braces back when i was a kid.
Here's my bite/teeth, pre-braces:
Midline is off 3-4mm, and the left side (right in pic) is pushing forward (5mm - causing the midline issue). I also have some crowding on the top. Bottom is not that bad, but minor crowding in the front has one tooth pushing forward. Plan is to remove the last pre-molar on the left, allowing the teeth to shift back to a proper biting position and bring the midline back to center.
and here's me today, upper 3m Clarity Ceramics:
That's about it so far.. I've had the top braces for about 5 hours now - all good thus far, definitely feels weird in my mouth, but after a week of spacers, the braces seem like they won't be all that bad. While I've been typing this out, I've even managed to eat a whole meal of real food (figured if I'm gonna be in pain later, I should eat now). Went into the ortho today with a solid mix of hesitation and excitement - I feel like I should have done this a while ago, but I'm just glad to be on the road now.
Updates to follow...
C in Boston
