They day of my consultation I was fitted with my upper arch set that moved rather fast however my ortho requested that I have my bicuspids extracted before fitting my bottom arch.
Extractions took place 12/6
Here are extractions after a few days healing not so gross:
A week later I came back for what I thought was going to be a bottom set fitted however I ended up with a rather neat configuration set to pull my canines back into desired position see the power chains connecting to a button rather than a bracket.
12/13:
There was a lot of dull aching pain in my mouth for a few days however that has subsided and I am feeling much more comfortable.
There was also some rubbing of wires against my cheek but with a few days of wax that too has become less of a pain to deal with.
Hey Ravin,
I am glad to see you have started your braces journey. This is a great place to document and have support when you need it. I look forward to following your progress.
