Hello All~
I had my 3rd adjustment about 3 weeks ago and the ortho removed 8 brackets (the ones in the back - top and bottom). For my next visit they plan on taking off more brackets and replace them (including the ones that were taken off at my last visit.) Has anyone gone through this before? If so what do you think is the reason I have to go through this process? In my opinion I think the brackets were misplaced on several of my teeth and once the shifting started my closed bite became open creating a cross bite. I would like to confront the ortho on this but I am not quite sure what I need to say. I would love to hear any advice or similar experiences anyone else had that may be similar to what I am going through.
Thanks
Deltawire
Bracket Replacement
Bracket Replacement
- jennielee81
This is not uncommon. Sometimes as the teeth straighten, it becomes necessary to fine tune the placement of the brackets. Sometimes it is to put on a different type of bracket; one that is more suited for a particular problem.
My ortho hasn't replace my brackets, he bends the wire instead. Sometimes I wish he'd just replace brackets as all the bends in the wire looks bad (in my opinion) as well as it being trial and error sometimes (again, MHO).
He did, however, want to replace my upper opals with damon 3's to do a torque that the opals were resisting. Didn't have to do it after all as the opals complied.
I still have a lower incisor that won't line up (after 19 months) dispite the bending of that wire every single adjustment!! I almost wish the darned bracket would pop off "accidentally"
so that they'd have to re bond it and maybe it would move the tooth better.
I certainly wouldn't go into your ortho with a confrontational attitude, I would ask him what his plan is with replacing all of those brackets.
So much of this process is trusting our orthos to do what they're trained to do even when it makes no sence to us. BUT, if you're concerned, you definately need to ask.
Keep us posted!
![wink :wink:](./images/smilies/wink.gif)
Keep us posted!
The reason I am concerned is because there are two ortho's that are in this office and it seems as though both have a different methodologies for my ortho treatment.
On my 3rd adjustment I was told that on my 4th adjustment I will keep my same wire and get wire ties, but instead I ended up getting 8 brackets removed. The ortho that removed the 8 brackets, wasn't the one I normally see AND she told me to make sure that she is there when I come back for my next visit.
I usually will try to ask questions when I am concerned but sometimes I feel as though they are glossing over certain issues using dental jargon and often times telling me anything to get me to feel comfortable.
I go back for my 5th adjustment next week and will keep everyone posted. Thanks for your comments.
