Let me start with a disclaimer, that what follows is my personal opinion:
Quoting Meryaten: "There's nothing that a properly trained ortho can do with Damons that he or she could not do with another brand of brackets."
I could not have said it better.
I don't use Damon (or any self-ligating bracket) because I like to see my patients every four weeks...one of the main selling points for SLBs is pushing adjustment appointments futher apart.
We have many patients transfer into our practice when the move into our area, and several have Damons....we will work with them, but often will remove them and place the traditional brackets (an no charge) that we use....just personal preference.
David: If you are unhappy with the current alignment of your teeth, then go with the extractions as prescribed...Personally, I use IPR only rarely, when there is a tooth-size discrepency (referred to as a "Bolton descrepency") between the upper and lower teeth. Often the upper lateral incisors can be too small (proportionately), creating an end-to-end relationship once the teeth are aligned...then you either reproximate the lower anteriors, or build up the small laterals.
Other folks are more agressive with IPR, using it as a means to alleviate crowding....again, just personal preferrence.
Thanks Rickysa, for your comments and opinions. It's good to listen from an orthodontist's perspective.
I'm still considering my "tricky" options. Will decide before the weekend.
I suppose orthodontics is really subjective in that it depends on whether one is comfortable with his or her present teeth. Some say my teeth look ok because when I talk or smile, people don't normally stare hard to notice the imperfections. Yet, I think those who are on braces and have paid thousands of $ natually want perfection for themselves.
Hi David, may I know how your teeth looks like now? Did you go on with the teeth extraction?
I M in a similar situation as you were. I had one template on my upper left side removed for brace a when I was 16 years old. I have never had braces on my lower case and now I have an open bite and difficulties saying some words. My jaw clicks from time to time to. I am thinking of doing braces to correct my bite. Because of the side effects I am facing today. I am not keen to remove any more of my precious teeth
