showerpik
showerpik
I just noticed the showerpik advertisement on the archwire hompage and decided to order one. I tried searching to see if anyone had reviewed this product but came up with no results.
anyone have this?
anyone have this?
I have been using this for about 2 weeks now and absolutely love it! As NotBob mentioned above, the pressure can be adjusted by turning the valve on the unit. The showerpik is a simple design, and because of this simple design, it looks like it'll last for a long long time.
I purchased the showerpik because i was newly braced and my teeth were too tender, that it hurt to floss. It also helps with the cleaning of my expander.
i rate this product a 10/10
1/21/06 - spacers and brackets
1/25/06 - 2 lower biscupids extracted
1/30/06 - lower archwire
2/13/06 - expander on uppers
![Image](http://tickers.TickerFactory.com/ezt/d/4;0;80/st/20060121/e/Since+I+began+my+journey%21/dt/-3/k/427c/event.png)
I just ordered the one for the sink a moment ago. I started with the shower model, but feel that I want to do this more often than once a day.
I would rate it a 10 out of 10 as well.
-Pat
-Pat
![Image](http://tickers.TickerFactory.com/ezt/d/4;2;54/st/20060110/e/becoming+a+metal+bunny.+/dt/-3/k/794b/event.png)
Pat
When you order it, tell them you found the info on Lynn's website. I told him that this is where I found it. Maybe they'll do an ad on the main page.
-We have to try to keep the site supported!![Smile :)](./images/smilies/icon_smile.gif)
Pat
Well, I received it. It took about one minute to install. I find that I use it 3-4 times a day in addition to the morning use of the showerpik.
It's simple, inexpensive and it works.
Pat
Unfortunately there does not seem to be an email address on their website. I wanted to order this way as well. I had to call.
If you would like, I can call and see if they have an email address in which you can communicate with them.....
I know that you are not the first person that is outside of North America and is interested in this.
Pat
