thanks for the kind words everyone, and i am glad to hear some postive comments on the black ligs. i wasnt sure, but i really dig em! but ill have to try something diff next time.
yes linda, my midline does appear a bit shifted, but i think that a lot of that is due to the fact that after a few weeks without the elastics my jaw kind of found its natural position to sit in. so i think there was a lot less actual movement of the midlines than it looks.
the reamining plan is to finish off the midline, get the bite locked in, have some bonding done to my small upper lateral incisors and get my lower centrals fixed up (chipped).
as for the hooks, they are much taller and hold the elastics a lot better. i frequently had them pop off the ceramics. not a problem with the metals.
after the last adjustment i was really sick of the braces for a few days, and was wishing things would finish up. that is the first time i have felt that way, but i am going to stick it out as long as it takes for the best result. 8 months, a year, whatever
thanks, chris
