here are my teeth (note that while you can't really see them in the picture, I have my wisdom teeth):
![Image](http://i69.photobucket.com/albums/i71/mikeybraces/2af3b53d.jpg)
I've now been to consultations with three orthos, and each recommended something very different. As you can see from the pics, I am class I on the right, and class II on the left (so my bite is half-good). It seems that my upper crowding is considered moderate (though I would have thought it worse than that). 5mm overjet.
Anyway, the first ortho suggested 3 extractions (2 upper bicuspids, and a lower on the right). 24 months estimated treatment. ~$3400 for metal braces (not including extractions).
The second ortho suggested 1 extraction (the bicuspid behind my canine on the upper left). He stated that while he thought it would be possible to treat without any extractions, it would cause my front teeth to push forward "too much". 18 months estimated. ~$4400 for metal.
The third ortho suggested no extractions. Says crowding is only moderate and, while treatment would cause my upper teeth to protrude a little more, it would be only a few mm, and that my face would accommodate it (lips full enough, etc). Says would create a broad smile. Suggests (1) Could do uppers only (not fixing bite but fixing smile) for $3200 and 9 months, (2) uppers and lowers for 9 months for $4500 not fixing bite, (3) uppers and lowers for 2 years for $4500 pulling in overjet with rubberbands, or (4) invisalign ~$5000 and 15 months.
What do you all think?
![Question :?:](./images/smilies/icon_question.gif)
