Here is my smile pre-braces. As you can see I have some gaps and an uneven "manner" about them.
I also unfortunately did not take any pictures right after I got braces. I started with upper brackets and spacers which were applied August 25, 2006. The archwire was not put on until September 15th so I have only had the archwire about 2 months in this next picture.
As you can see my teeth are not so uneven but the gaps are still there. I've only had the archwire 2 months, as I said, so much work to be done on closing those gaps. This picture was taken one week after I had the bottom brackets and spacers put on. As you can see my right canine needs to be pulled in with the rest of my bottom arch, but other than that my bottom teeth are pretty in line.
Now for the "real" problem in my teeth. The tooth I have deemed the "wayward molar".
As you look at my arch everything looks in line except for that pesky little molar on the right side. That is where most of the work lies. I should add that before getting braces I had my two wisdom teeth on the right side (#16 and #17) removed. The bottom wisdom tooth (#17) was impacted and as a result grew in sideways. The upper wisdom tooth (#16) was removed as room was needed to be made for the wayward molar. You can see in the above picture where that wisdom tooth used to lie.
My next adjustment is Dec 8th where the bottom archwire and bands will be put on. I will post pictures of all that after the appointment.
The journey has begun...
