The problems are that I have a baby canine that is still in place, the adult canine is behind it so the baby is very loose but I have a small peg lateral incisor that will have to come out too because there is not enough space for my new adult canine to come through.
This means that my new canine will transform into a lateral incisor and my first premolar will become my new incisor - complicated huh!
I didn't have to go down the orthodontic route, I could have had extractions and implants (too expensive!) or extractions and a bridge. I so very nearly took this "quick fix" bridge option but it would mean the loss of perfectly healthy teeth and although it would be better in the short term, it would need maintaining for the rest of my life. So I decided to go for the full works, the long haul - my reasoning being that a few years in braces would give me a set of teeth that I would be proud of for the rest of my life.
My treatment plan is 2-3 years and I am having stainless steel braces on my uppers and lowers. It seems alot of work and time to correct one tooth! But of course everything that is wrong in my mouth will get corrected too, overjet, overbite, crooked teeth even though these things never really bothered me.
As I go into this treatment I can honestly say I am scared to death but the thought of having a prominent gap at the front of my mouth which is what would happen when my baby canine finally gives in and comes out is worse. So here goes...
Here are some of my start photos....
This is my start photo, see the small peg tooth on the right of the middle tooth, well this one and the baby tooth on the right of it need to be extracted to make room for the adult tooth which was erupting through the roof of my mouth 6mm from its correct position.
You can see the adult tooth here coming behind the two that need extracting.
This photo was taken after I had had 6 extractions ready for my brace to go on.
Heres my new brace, it was fitted on the 10th Jan 2007. My orthodontist has not included my adult tooth yet as its too too displaced but it should be incorparated after about 3 tightenings. Also the bottom back teeth are not in yet either, I think they will be added onto the brace in due course but not sure when.
I will keep you posted!
Sarah x
