My teeth have always been healthy but I was not happy with my gummy smile and spacing between my teeth. Two years ago, I went to my dentist asking what can be done to improve my smile and he suggested braces
The idea of wearing braces for two years in my thirties was not at all appealing
After much contemplation, I decided to have an ortho consultation. After the consultation, it made sense to do whatever I can to keep my natural teeth and have a great smile.
It took almost a year to get my act together. On Halloween of 2006, I got my upper braces.
So the journey begins...
Before Braces (October 2006)
Upper braces. GAC Innovation-C
When the braces first went on, I expected much more discomfort. But it was not bad at all. There was some discomfort but no major pain. I ate soft foods for two days and slowly graduated to braces friendly solids. I cut my food in small pieces and chewing is no problem.
The complete package. Bottom braces and two bite pads added on December 5th.
The 1st top archwire was nice and white. As you can see, the white coating eventually rubbed off from my compulsive brushing.
First Adjustment and Progress (January 2007):
It's been 11 weeks since b-day. My first adjustment was eventful. I got a new thicker white upper wire, power chains, and 1 elastic. Much more than I expected. The bottom incisors were shaved off a little to create space for them to align. The lower wire will be changed in February.
My ortho changes only one wire per appointment. My bite has also improved. My overbite is now only 2mm. I started with 8 mm.
The spaces are starting to close with the new white archwire and powerchains.
Check out the lower arch. It's looking much straighter. I have only had the lower braces on for 5 weeks
