First things first, so i have to say this forum is excellent and i'm enjoying reading your posts.
I'm 32 years old, when i was young i had a very misplaced teeth, and in that time, fixed braces were very expensive, so i used the removable ones for several years. The end results were very reasonable, and people always said i had a good smile.
Several years ago, since i can afford fixed braces (and the costs associated to them like regular visits for adjustments, etc) i've been thinking of put braces to finally achieve the smile i always wanted. I think I have a very reasonable smile, from several angles they are OK, but they are not perfect, they are a little inclined, and the canines are a little misplaced.
I think that should be relatively easy to fix, from this two pictures, what is your opinion? Will i get visible results by using braces? Is it possible to achieve the perfect smile we all want?
I would like to ask you one question. I'm a boxer (only training and occasionally some spar ring), is there any special mouthpart to protect my braces?
If i'm hit is it possible to dislocate or break the braces? Has anyone practice combat sports while using braces ?
Thanks to all! Your stories are great and your progress are amazing and very inspiring !!!
