Starting out in May of 2009...you cannot see it but I had two teeth extracted on the top the week before:
Taking another picture the end of May 2009, already showing movement:
June 2009
Here midline is getting significantly "off" due to pulling teeth back to fill in the extraction sites...The silver colored wire is to pull up my bite:
Here is a poor quality but current photo...very "ugly ducking" as they are pulling back the side tooth in prep to realign the center tops....Looks pretty bad haha. Also my bottom lip always seems to be in some very minor state of swelling with the bottom braces....annoying little things they are!
I'll try to upload a better photo similar to the first ones (taken outside) soon!
