Does jaw surgery change your nose?
Does it?
Short answer - yes.
Longer answer, upper jaw sugery will always have an aesthetic impact on your nose. In my case i'll gain 1mm each side and the tip will turn up a little, but every surgery is different. The person who can give you the most accurate information on how you'll be affected is your surgeon, so best ask him.
- marycotter5678
For upper jaw surgery (advancement), I was told the nose can get a bit wider and maybe pointer tip - also your nostrils might show a bit more. I'm not sure how it affects the nose if your having your top jaw moved back but I would assume the opposite of an advancement..?
As for lower jaw only, it does not affect your nose at all from what I've been told.
Double-Jaw Surgery: Lefort I & BSSO (May 4, 2010)
I had double jaw surgery. My nose is apparently technically smaller - it's shorter and the tip points up a little, but it's also wider because my nostrils are more flared. I had double jaw surgery for my underbite.
If you picture it in your head, when they push your upper jaw forward, as they did in my case, my nose went up and out. I imagine that if it was to get pushed back, for an overbite, it might get a little longer and narrower, but I'm no surgeon.
- Alison
Just an addition to my post above, i'm 26 days out of surgery and the other day I asked friends and family if my nose looked different. After close inspection their verdict was 'maybe it has but we can't really see much difference'. I can't even tell myself for sure. So all in all the change (if any) for me has been unnoticable.
