I posted a thread a few years ago asking if braces could fix an occlusal cant. After some recommendations from the board to get opinions of several orthodontists, I did just that. All of the orthodontists that I went to said it couldn't be fixed without oral surgery, except for one. I couldn't afford oral surgery since I didn't have health insurance so I decided to go with the orthodontist that said he might be able to fix the problem using TAD implants for absolute anchorage. Here are the results so far:
Before braces:
The cant is actual worst than it looks in the photo, which you can see below.
Right after braces were put on:
Here is my initial skeletal view:
After TADs:
Skeletal view after TADs:
This was after about 1.5 Years. Since then they have just been correcting all the spaces straightening all the front teeth. TADs can allow for some pretty heavy teeth movement it seems.
