Extractions: 4 total, premolars at top and bottom
The reason for my post is that
Smiles concerns prior to braces:
overbite - upper :: caused "bucked teeth" smile, mouth poked out, somewhat difficult to close
crowding - lower :: made bottom tooth look discolored
I've posted before about second guessing extractions. That was such a huge step for me that I actually cried in the surgeons office during the extraction. However, I remembered what I'm working toward and I relaxed.
Ortho is now suggesting TADs...to close extractions (of course) and prevent back teeth from moving forward. He showed me a patient file where he used TADs and it looked weird. Bunched up gums (ortho said that's normal while teeth are moving and the gum eventually move back into normal position). My issue is that now he is suggesting I use TADs but saying that it will cost and additional $800. WTH?!!? He should have told me this before I signed the $8000 contract and had the teeth taken out. Ultimately, I know its my fault but I'm pissed and confused about what to do.
Please help, I will clarify if necessary as it is 1am and I'm trying to put together sensible thoughts.
