just got lingual braces - no pain or pressure
Hi, I just got lingual braces three days ago (both top and bottom). Apart from terrible pain in my tongue, I don't feel any pain or pressure on my teeth. Is it normal?
I remember reading similar questions on this forum, but never thought it would be my case...
English is not my native language
I didn't get pain or pressure in my teeth, I went back two weeks after having all fitted to check this out, but they showed me where I had movement against a model of my teeth before treatment. I can only think of the odd time in the last 9 months when I have needed to take medication for pain, and quite often I have no pain or pressure. I have certainly had a lot of movement, despite the lack of pain.
The sore tongue, try to drink lots of water and use plenty of wax, it gets better with time.
Good Luck
Good Luck
Hi xTc,
I have Incognito, I think this is the only brand of lingual braces available in Europe. I found my doctor on this website lingualtechnik.de, because the idea of wearing braces on the outside was freaking me out.
It's not even been a week since I got them, so I am still getting used to the whole thing. They feel huge and sharp, and I spend like hours every day cleaning them after I eat.
The speech is still bad, and I have to explain people that I wear braces. Actually, I don't feel it improving so far, but it might be because every day I have to speak in three different languages, two of which are foreign to me.
Ah thanks for replying Dorag.
I'm sure your speech will improve, and I admire the fact you speak multiple languages! That must make it much harder because I assume you have to place your tongue in a lot of different positions when speaking the different languages?
I am looking at getting lingual braces called In-Ovation. They only straighten the front 6 teeth, and my ortho said that they are a good (Although inferior) alternative to incognito.
Do you think these would be easier on speech?
Hi xTc,
these look really tiny comparing to what I have, so I think they definitely must be easier on speech.
So far I adjusted the best to speak French, in English s, ts, th, and sh are the worst, and in Russian I can't pronounce half of the sounds, despite all the practice I've done in the past few days.
Why don't you want to have incognito other than because of the speech problems?
I had a few bits of glue that I couldn't floss out, and I asked my ortho to remove them when I went back - I think after 3 wks, I cleaned between my teeth with a water pik for that time.
I remember them saying it's tricky to know how much glue to use - too much and it gets stuck between the teeth, too little and there is a risk the brackets could come off, and you would have to go to the effort of getting replacements custom made.
They cost far too muchdorag wrote:Hi xTc,
These are around £2k and incognito are around £4k.. so it's double the price for me..
Hello All,
I just started the process two days ago. I opted for ceramic bottoms and linqual uppers which i will be fitted for in a few weeks. However, now I'm concerned about the tongue situation. I have to talk quite a bit as part of my job, which is why I wanted linquals to begin with. But if the cutting to the tongue is unavoidable and as painful as everyone describes, I may have to reconsider. Have people experienced just a many problems with having upper linquals?
Hi
I have the same and I have no issues. I did take 2 days off work after having uppers and lowers fitted and four extractions on the same day, like you I talk a lot at work. It was nice to have a couple of days to myself to chill out, but nobody noticed any difference in my speach, I didn't notice any difference after day one. Re cut up tongue, I just used wax and plenty of it.
