Everyone at work is like, what's wrong with you!!!! Thank goodness I do not have any speaking engagements until Feb 2010, otherwise I would be screwed!
Eating is getting better, I just cut and swallow !
MY SPEECH!!!
Hi Lisa - what kind of braces do you have? Are they Incognito/iBraces? I had a few problems with speech when I first got mine, but I soon adjusted. I have also found that my speech varies each time I get a wire change - I had real problems with one wire (it was on the bottom arch) and then as soon as it was changed I had no problems whatsoever! And eating gets much easier. Hope things get better for you soon.
Hi LB I have Ibraces. I have not had a wire change or adjustment yet. My speech is getting better but i would say I am only 75% there. I am not really chewing when I eat, which cannot be good for me.LB wrote:Hi Lisa - what kind of braces do you have? Are they Incognito/iBraces? I had a few problems with speech when I first got mine, but I soon adjusted. I have also found that my speech varies each time I get a wire change - I had real problems with one wire (it was on the bottom arch) and then as soon as it was changed I had no problems whatsoever! And eating gets much easier. Hope things get better for you soon.
Practice reading out loud for about an hour. That should get you speaking well more quickly.
Developer of:
http://sixmonthbraces.com/
