Thanks every1 for stopping by & giving me advice
I really appreciate it & it's helped reassure me a bit.
I just can't see how this lisp will go no matter how much I practice because I produce alot of saliva & always have done (too much info I know) so it's rattling around my brackets when I speak making a lisping sound when I talk & my tongue can't get away from these huge brackets becuase there is nowhere else to put it so I don't see how it will improve
It seems to be getting worse. I was doing ok & was managing to kind of just tickle the brackets when I spoke. It has come & gone but slowly getting worse I think.
At work again with my wax again but I sound worse
I took my wax off last night for a few hours before bed. Have to sleep in it though to give my toungue a break. I'll try go all weekend without it but I don't know if my tongue will be able to take it for too long.
Also will my tounge toughen up? At the moment its sore from my front brackets & the BIG hook on the last tooth is constantly sticking in the side of my tongue. I don't see how it will get used to it? So painful.
I've also discovered I can't floss anymore. I guess the glue is stuck between my teeth. My floss can only get halfway up my tooth if that & then breaks the more force I use & then I struggle to get it out. Tried using a tooth pick & that snapped
Rang my ortho's office today & the girl on the desk said it was probs the stuff they use to bond the brackets on with but that I shouldn't be using floss now & conentrate on using my interdental brushes
but I can't see this doing a good enough job under my gums
I don't want to get gum disease. Had a mild case many years ago before it actually turned to gum disease & suffer from bleeding gums if I don't floss.
Does anybody else just use the interdental brushes?
I use superfloss on my bottom teeth & I will continue to do so.
This is going to be a rough long old ride me thinks.
Gosh shysmile you've adapted so quick. Hope I do too & i'm not 1 of these people who has problems with speech throughout. Was you lisping much to begin with? I don't know if I was really.
Is it easier to talk once the wire is on then guys?
Thanks again xx
