Hey there, does anyone know of Incognito for milder cases which involves braces on only the first 6 teeth? I have a very mild case and have a consultation with an orthodontist in a month but I want to see if I can collect any info on this? I was told it is used for milder cases, which I believe I have. Is there a certain "model" for these?
Only the first 6 front teeth have braces on them, and they are lingual.
Incognito on 6 upper FRONT teeth only.. Anyone have any info
Re: Incognito on 6 upper FRONT teeth only.. Anyone have any
Yes they are called stb social 6 braces! Research on the net for them.
Are these available in Canada? I thought Incognito made an appliance for 6 teeth?Ruzzzz wrote:Yes they are called stb social 6 braces! Research on the net for them.
Anyone hear of any luck with these?
well at least the show-cases at the Ormco page look quite impressive (but that may be always the case).
