so, i have an internal retainer, the one with 6 teeth on the lower jaw and moudled with cement. today, i was chewing some gum and the retainer on the two teeth in the middle on my lower jaw, suddenly moved. i went to check it out and sure enough i could shake it pretty well with my fingers.
The problem is, im currently using invisalign retainers as well, and they were moudled when i had my internal retainers on.
if i try to re cement my internal retainers, would that be a problem since my invisalign are already set?
should i just ignore the shakiness and leave it, since the other 4 cement are still held in place well?
thanks
Internal retainer shaky
Re: Internal retainer shaky
well , submitted in the wrong forum.
apologies.
apologies.
