dry mouth
dorazabi10
dry mouth
#1 Post by dorazabi10 »
hi..i have been one month with incognito lite on my upper jaw and i have filling since Extreme dryness on my mouth and throat and its very frustrating ..have anyone experience this? cause my Orthodontist says he dosnt know this thing
Shelleyt
Re: dry mouth
#2 Post by Shelleyt »
I definitely had dry mouth. Over time (I would say 3 month mark was biggest improvement) it got better, but I still am about twice as dry at night as usual. Sleep with a humidifier and buy dry mouth products if you can
dorazabi10
Re: dry mouth
#3 Post by dorazabi10 »
Did you have a dry mouth even after you finished with incignito? :oops:
dorazabi10
Re: dry mouth
#4 Post by dorazabi10 »
[quote=Shelleyt post_id=500355 time=1518544649 user_id=27830]
[/quote]
dorazabi10
Re: dry mouth
#5 Post by dorazabi10 »
[/quote]
Shelleyt
Re: dry mouth
#6 Post by Shelleyt »
Not finished yet so I can’t say
dorazabi10
Re: dry mouth
#7 Post by dorazabi10 »
Shelleyt wrote: Sun Feb 18, 2018 7:16 pm Not finished yet so I can’t say
did u also experience changes with food tast?
Littlemiss18
Re: dry mouth
#8 Post by Littlemiss18 »
Ever since I got my braces I’ve had a dry mouth also everyday except the days I’m swimming which I find very weird but not only that I also have a dry lips a lot since having the braces I have found when you drink water keep a little bit in for atleast a few minutes and it will help reduce it but I still have found anything for my lips since lip balm and that don’t completely work
HarryPotter69
Re: dry mouth
#9 Post by HarryPotter69 »
dry mouth with a bad breath always what should i do
HarryPotter69
Re: dry mouth
#10 Post by HarryPotter69 »
i tried elachi https://www.cosmosmagazines.com/who-was ... arie-ryan/ and a herbal things it helped alot
djspeece
Re: dry mouth
#11 Post by djspeece »
This is an older post, but some have used a product called Biotene for dry mouth...also, avoid mouthwashes with alcohol. Best of luck to you.
