mackenzie wrote:You have really nice shaped teeth, I bet they will look amazing when they're done!
Thank you. I hope it turns out that way. I think I will need some veneers one on each side of the two front teeth, but we'll see. They said they can't really tell till they straighten out.
I will do whitening as soon as these are off.
7/7/06 Damon 3's on top, Damon 2's on bottom
03/18/08 Naked
For pics to show up they have to have the closing code at the end. I don't use photobucket, but with imageshack it gives two codes for posting to forums ... one is for larger pics, and is the thumbnail code and the other is the direct link for pics of 500 px or less. The direct link code shows the pic in your post.
Here's your second pic ... and all I did was add the
For your ticker. If you go to the 'How Do I Do It ... ' forum viewforum.php?f=20
You'll find that Lynn has written about how to include a ticker in your signature. If you follow her instructions, you should find it straight forward. viewtopic.php?t=11743
Thanks for posting those for me. I fixed the ticker thing too.
03/18/08 Naked
Hang in there it will get better after the 1st week. I wanted mine off after the 1st hr of having them. Your teeth will strighten out and youll look great! So dont worry it will all be worth it in the end. Use lots of wax. Take care!
Im 30 Female
TMD, Crowding, Overbite
Clear on top Medal on bottom
Beauitful smile wishes to Everyone!
Skinny
