Eating...
I did eat popcorn and paid for it with a gum infection. I hadn't got a piece of popcorn out of my gums and the consequences weren't fun at all.
I also don't eat sticky candy, but I do eat smooth peanut butter.
With things like steak, I cut much smaller pieces than I did pre braces. I also love nuts and raw veggies, but no longer eat nuts and my veggies are cooked. If I feel I want more calories, good old Carnation Instant breakfast drink helps!
With your brackets popping off, it might be a matter of your teeth somehow hitting them. Make sure at your ortho's office, you do a lot not only up and down motion with your jaws, but sliding back and forth, side to side, also. I had a problem with popping a bracket, it was because of the side to side sliding situation. Your orth might also need to move the brackets lower or higher on the teeth (depending if they're on the lower or upper jaw).
Jembrace
Jembrace
1st wire change June 2007
~No dream is ever lost if we never cease to try~
Moody Blues
