Your smile looks great!!! I think with just a little bit of shaping, you would be much happier with your lower arch. My lower arch isn't perfect because of uneven teeth wear and I asked my ortho about it before debanding. He assured me that after he did some shaping, my lower arch would look better. He was right. My lower arch definitely isn't as level as my upper, but the shaping really helped my lowers look better.
Chris
Thanks for the reply. I know shaping would probably make a lot of difference, but the problem is he already "did" the shaping. Hopefully I can convince him otherwise when I go back in for my retainer check.
