If someone can please read this lots of pain
Sorry but I'm not sure how the brace relief works. I think that the main thing is to try to stop the irritation form the wire or bracket as this will give the area time to heal. I'm not sure if there are products that help with the healing process, hopefully somebody else might know.
Brace On 10th November 2006
![Image](http://tickers.TickerFactory.com/ezt/d/4;10722;104/st/20061110/e/I+got+my+brace/dt/6/k/efcd/event.png)
I use a medication called Kenalog. It needs a doctors RX, but it works wonders for me. A little goes a long way. If you can get ahold of some, put on a blob of wax on the bracket and this stuff on the sore - it heals in 2 or 3 days. Also, avoid any foods which can cause irritation (oranges, cantaloupe, spicy...) and if you are like me and like boiling hot coffee or tea, take it down a few degrees. I also agree with the others - a trip to the orthos office sounds in order to check that wire (if you have self ligating brackets you might have a popped open door that is rubbing the wrong way).
I'm not sure where to buy them, but a friend of mine who was recently debanded gave me these things called "cankermelts" They are little round, flat things that you position over the canker sore, and they soothe and help heal, plus they create a barrier that makes it hard for the bracket/wire to cause more irritation... the only drawback is that after a few hours (or overnight, if you sleep in them), they tend to get gooey and stick in your brackets, and it makes the canker a little sore to get it off. Overall, I liked them though.
![Image](http://tickers.TickerFactory.com/ezt/d/4;10722;96/st/20070307/e/my+brace-day/dt/-2/k/81fd/event.png)
peroxide
I noticed no one mentioned peroxide rinses... I have always been very prone to getting sores in my mouth... any sort of irritation caused a sore... rinse with peroxide out of the bottle a few times a day and it helps heal it real quick.
I used to get canker sores all the time. There is something they have put in tooth paste that really triggers it since I have been braced. Especially the whitening tooth paste. I think it is sodium laurel sulphate. I switched to just plain arm and hammer baking soda tooth paste and I never get them. But if I use the triple whitening kind I can feel under my tongue start to swell and then the canker sores start to appear. My husband is finding the same thing and he isn't even braced. Just something to watch for because now I never get them.
While your mouth will indeed toughen up and be able to handle the brackets no problem, you don't have to put up with a poking wire. Your ortho can polish it smooth in no time flat.
It's hard to believe now, but you will get to a point where you don't even notice you have braces on!
![Image](http://tickers.TickerFactory.com/ezt/d/4;46;116/st/20080213/e/Braces+OFF%21/dt/-2/k/7d70/event.png)
You can also try Biotene mouthwash. I started using it on a recommendation a few people posted. It has no alcohol, so it doesn't burn like Listerine or Scope. It states that it heals mouth irritations and also helps with dry mouth. It has a mild taste too. I just buy it in the grocery store in the dental section. Good luck with the pain ![HelloWave :-1](./images/smilies/hello.gif)
self-ligating metal brackets all around
![Image](http://tickers.TickerFactory.com/ezt/d/4;10100;96/st/20051123/e/In+full+braces/k/c6a0/event.png)
- jennielee81
It will toughen up. I've had countless sores in my mouth from brackets and wires rubbing. I stopped going in to have wires clipped after a few months as my mouth really stopped reacting to it. Your description of your sores is quite common...at least for me
I also use non Sodium Laural Sulphate toothpaste (Rembrand Canker Sore). Read the ingredients. Almost ALL toothpastes contain SLS even if they are for sensitive teeth, all natural, organic....etc. Read the label.
Even if you continue to have rubbing, your mouth will toughen up. It'll take longer, but it will happen.
Be patient and have a positive attitude.
Use what is available to help and be patient. We've all been where you are and we all get through it. It is uncomfortable but it passes.
