Band free braces (pic)
no molar bands either
I have brackets on my molars just like the other teeth. (even on the crowns). I didnt even realise that was uncommon till now.
I have bonded brackets up & down, 12 & 12, and my right bottom first molar even has a fissure in it (being crowned after the braces are off). They glued the buccal tube right to it. That's an anchor tooth which is not moving the way the others are, and apparently they feel (and the dentist agreed) that real teeth will respond/perform better than crowned ones.
I do have one crowned tooth that's braced as well and they bonded that one as well; no problem.
At my consult I asked about whether they would use spacers and bands on my back teeth, but the consultant told me 'no, we don't use bands here.' not sure if she meant in my case, or in that practice. didn't really matter...
bands or bonded, I think it depends on the case, the practice, the doctor, etc.
-tommy
top arch braced 3/21/07
new wire on top 4/19
bottom arch braced 4/19
buccal tube lost on 5/4, replaced on 5/5
new bottom wire on 6/26 (I think)
top & bottom chains (round 1) installed on 7/24 (ouch)
I've had my braces on for only 6 days and was "checking" them out in the mirror the other day and noticed the same! I'm feeling luck (now that the tenderness has gone a little) it gives me two (well four.. two top and two bottom) teeth on each side that i can chew with!. I never thought i would miss bitting down on something so much
I have bands on my first molars, but when the ortho decided to band the second molars, I was able to talk him into using the bonded tubes to avoid going through a second round of spacers. This was done with the understanding that if we had problems with the tubes popping off, he'd switch to bands.
It's been six months and none of the tubes have popped off the second molars. I think I'm getting close to the end of treatment, so it looks like it paid off. I really like the bonded tubes vs bands, they have a much lower profile.
- jennielee81
I too, have only brackets bonded to my molars. I have a bracket on each 2nd molar, but there was only a wire in them for about 2 months.
This is not odd at all, simpley different.
Yeah it's good to know I'm not alone in my band-less treatment! However, I have no crowns so I'm not really sure why he went for no bands in my case. Oh well - they are coming off in less than a month! I look forward to posting pictures then!
Upper ceramic and lower metal braces
Round #2 - Had braces as a teen for 4 years!
Treatment time: 14 months
Braces on: July 19th, 2006
Bottom braces off: August 29th, 2007
Top braces off: September 19th, 2007
BLWR on bottom and Essix on top!
