I'm guilty... I wet the toothbrush... apply the toothpaste... wet it again and off to brushing my teeth...
I Tried the dry toothbrushing but that really didn't give me the feeling of clean for some odd reason so I'm stuck with the wetting the brush technique.
~Tim~
Adjustment Sept 14th, 2018
Braces off April 02, 2008
When I was younger, I thought the taste of toothpaste was too strong - so I wet it before I started brushing. I just haven't bothered to change the way I brush since I was 6.
Most denal professionals recommend wetting the bristles with warm water first to soften them--this helps to prevent any potential damage to the gingiva
I always wet the brush until my dental hygienist suggested that I dry brush and wait a few minutes to rinse so that I get the full benefit of the tartar control ingredients in the toothpaste.
It has been hard because after years of wetting the brush first it is hard not to automatically run water over it. So about half the time I wet the brush and half the time I brush with the dry brush and wait a few minutes to rinse.
After watching the episode of MythBusters where they test what kind of germs and 'matter' lands on toothbrushes while sitting in the cup, if I wasn't already a wet brusher I would convert...just to rinse off the brush first...... GAG.
I wet the brush first and shake well just to soften the bristles a little then brush. I don't wet the paste. When you have your teeth professionaly cleaned they don't use water at the time of using paste (well my dentist doesn't). Toothpaste is 75% humectant (typically Propylene Glycol) and water anyway so plus your saliva extra water is not really necessary. But it's all a case of personal choice, doesn't make much difference really I don't suppose
I rinse the toothbrush to clean & soften up the bristles, put toothpaste on and then wet the bristles again. Though I heard that dry toothbrush works better in cleaning than wet toothbrush. I can't remember where I read it.
