Help! I can't keep my teeth clean!!!
lindesd
THANKS!
#16 Post by lindesd »
jennielee81 wrote:I would definately ask for a different hygenist next time you go for a cleaning.
You don't need to say why, they probably already know. :?
You are too cool! So glad to have an expert on this site to get us worry worts thru this! :)
Stacey
ScottR
#17 Post by ScottR »
I would highly recommend you try the Sonicare toothbrush. I have zero plaque since I switched from my maunal toothbrush. It really works for me.
Betty Bat
#18 Post by Betty Bat »
I was a little "plaque factory" while I was in braces. I used a Sonicare 7300 toothbrush, I flossed, I used my proxy brush. But, some people just produce more plaque than others. I ended up going for more frequent cleanings while I was in braces. My dentist suggested coming in every three months - I countered with a suggestion of every four months.
So, it may not be a comfort to you, but I can tell you that you're not alone.
