How often do you get a professional clean with braces?
hj55
#16 Post by hj55 »
Before I had braces my dentist would clean my teeth at the time of my checkup every 6 months. Cost £16.50. I very rarely saw the hygienist.
When I had my braces I started having appointments with the hygienist but that was included in the cost of my checkup so still £16.50.
I had additional appointments with the hygienist in between my checkup for £16.50 so my teeth were cleaned every 3 months. Now the braces are off I haven't decided whether to continue with a 3 monthly cleaning or revert to 6 monthly - I do have fixed retainers top & bottom.
seriousthinker
#17 Post by seriousthinker »
Hi,
My dentist is fantastic and gives me a scale and polish at every 6 month check up (nhs £16 odd). He doesn't take too long doing it though. Id say 15 mins max.
ST
BraceFace2o1o
#18 Post by BraceFace2o1o »
Thank you all for your replies!
I will definitely ask my dentist at my next appointment to see what he suggests.
I'm hoping it will be a simple process, as ideally I'd like a professional clean before getting a brace and during too, just got to find out where I can get that done locally.
jackjack
#19 Post by jackjack »
Since braces I get a cleaning by the hygenist every 4 months. And this is a very thorough cleaning with scaling and use of a waterpik thing that cleans under you gums and sometimes with an antibiotic fluid added to the water to help with gum inflammation. She also does a prophy at the end.
