That said, after over two months, my brackets are still tooth-colored. The ligs do stain--the clear ones I had put on first turned a disgusting neon yellow in about two weeks--but like everyone says, you do get them changed frequently and some colors resist staining better than others.
Right now I have a light blue color and it's resisted staining very well. They've faded slightly and taken on a slightly greenish tinge after 2.5 weeks, but it's not a nasty color at all.
You might want to ask what brand of ceramics your ortho uses. I have Mystique, and I'm very happy with my choice so far. The only downside I've discovered is that because of the size of the brackets, it takes more force to stretch the ligs over them, and it hurts when they change the ligs, whereas the ligs seem to go on the metal ones much easier. I don't know if that's a common experience, or if the people in my ortho's office just have bad technique!
