Think Pink: Powerchains!
I'm a little apprehensive that things might be really painful tomorrow when I wake up, since the lowers are all really quite sensitive after just a few hours of wearing them:
I have to tell you that I'm lovin' the pink powerchains, they look great on your very white teeth! Hopefully they close those gaps quickly without as much pain as I usually have!
~Hannah
Top braces: 4/28/04
Bottom braces: 11/16/05
Last Adjustment: February 28, 2006 where they gave me a new bottom wire and attached my impacted canine, newly bracketed, to the wire! OUCH!
~Hannah
Top braces: 4/28/04
i have a navy blue powerchain, and i'm sad to say it makes my teeth look way yellow!! I didn't think that it would, but it did . I have navy and light blue ligs on top, and a navy powerchain on the bottom. It looks pretty cool, but it makes my teeth look yellower than they are.
I suppose its alright i mean people can't be lookin at the teeth that much i mean they can't miss the ligs lolz.
O.o*Shelby*o.O
braced on:9-29-05
http://tickers.TickerFactory.com/ezt/d/ ... /event.png[/img]
braced on:9-29-05
Thanks for your kind words everyone!
Re the yellow effect: some colours seem to make teeth look whiter than others. Pink does a bit, but the strong pink I had before really did. Whereas blue possibly enhances it, as they're at opposite ends of the spectrum (or something).
I held a lime green one up against my teeth and that seemed fine, but it was so bright there wasn't much contrast. The dark green would be very good for making teeth look whiter I think.
