I use Sonicare electric toothbrush to clean the teeth. I am considering buying a Rotadent clectric toothbrush. Will it help in cleaning between the teeth while on brace?
Thank you very much.
Will the Rotadent toothbrush help cleaning teeth with brace?
I have a rotadent & it is BY FAR the best toothbrush I've ever had!! It is incredible & to answer your question, yes it helps clean the braces TREMENDOUSLY! I highly recommend getting one!!
Spacers-9-19-05
Top Braced-10-03-05
lowers on-10-17-05
appliance installed in mouth 10-17-05
2 extractions on 8-3-06
2 years treatment time
Dr says I won't finish on time
Top Braced-10-03-05
lowers on-10-17-05
I purchased the Rota-Dent from my ortho and LOVE IT! Mine came with a few different brush styles that work great for getting under and around the brackets. You get that "just from the dentist" feeling when you use it. I was also told by my hygenist that the rotary action has been proven to be much more efficient than others.
I also got the Rotadent from my ortho and I love it. The brush heads that are made specifically for braces work soooo well, they get into all the spaces under the wire and work very well to clean my crowded lower teeth.
As a plus - my husband's dentist recently recommended that he use the rotadent, so he is now using it too and loves it just as much as I do. The brush heads are really easy to change, so we can share the toothbrush with no problems.
Top brackets and spacers on 2/17/06
Molar bands on 3/6/06
Extractions and full braces 3/27/06
Update: 22-24 months total time in braces!
