ELASTICS--HEADACHES????
ok i got my first adjustment on tuesday. thay change my archwire on top and bottom, give me a powertrain on the front top teeth 6 of them, then they put on the elastics on both sides on the mouth in the shape of a triangle. then the tech tell me that i would have a headache. ok i thought then she said the whole time im wearing them i would have a headache. now i have to wear them 24/7...so has anyone the elastics and headache if so how long did they last..because i have had a headache since tuesday the day of my adjustment. thanks mateo's
Sure did. I had these tension headaches for about 3 days after initially getting my elastics. Like everything else you go through with braces, you eventually get used to it, and the headaches do go away.
hi MATEO'S!
Yep, I still get headaches from them & I only have to wear them at night when I'm sleeping (after about 6-7 months of wearing different config's 24/7)....I had a headache for about 1-2 weeks after each adjustment...then every now and then certain sides of my head would hurt. Hang in there-I've had to wear 4 elastic at once 24/7-the pain was immense-but the progress of your bite will be 100% worth it. I know that the hardest part for me is just getting through it and trying not to think about it too much-which is hard!
good luck
Renee
good luck
Renee
