My teeth are yellowish now that i have braces :(
it sucks b/c my teeth are yellowish after 6 months of braces....
is there any way to make them whiter while being braced? I mean i do brush 2 times a day...
also, is bleaching a safe method after i get my braces off? Is it safe for teenagers?
Braces On: 11/1/05
Braces Off: ???
I also have the yellowish problem going on which is really annoying. I recommend a stain removing toothpaste or powder such as Eucryl which is really cheap in the UK and really helps to brighten my teeth up. Probably best to be careful what you use while the braces are on - you can get them properly cleaned p when they come off anyway...
LoobyLou x
LoobyLou x
Yeah mine got yellow & dingy looking so I started using listerine whitening pre brush rinse. It helps brighten my teeth & I feel better of course when they look white, clean & all. I use it everytime before I brush. Try it:)
3/28/06 8 Spacers
4/6/06 Fully Braced(Ceramics)
7/11/06 3rd Adjustment
Don't Frown. You never know who's falling in love with your smile.
no whitening products..
I was also told not to use ANY whitening products while in braces because after it's removed you can end up with marks where the braces were attatched so I was told to wait til the brace is removed before using any kind of whitening products, including whitening mouth wash.
mother of one.
I agree with KK.
PAYOKI- These whitening products will not make such a dramatic change in the actual tooth color. Especially the whitening mouthwash I suggested. Being that you only rinse for 30 seconds I highly doubt it will actually whiten the bare tooth. I suggested the mouthwash to those who had that dingy look & wanted to BRIGHTEN the teeth. Its just called Listerine whitening mouth rinse but it does not in anyway whiten teeth. Like I stated in my last post it does help brighten my ceramics that is until I drink or eat something.
3/28/06 8 Spacers
