How long does it take....
How long does it take to get the braces put on (top and bottom)?
I tried doing a search but I wasn't quite sure what key words to look up.
I have a timing problem...I'm supposed to get my braces put on tomorrow morning at 7:30am. Well at 11:00am I have an appt in another city 2.5 hrs away. Will I be done by 8:30 to get on the road? The receptionist at the dentist office thinks I will be done in an hour. How long did it take some of you?
Thanks in advance for your help!
That depends - I missed a doctor's appointment because mine took over two hours because of my TMJ. If you have TMJ or any other jaw problems it can take much longer. I had a really, really hard time keeping my mouth open through the pain. My orthodontist stopped frequently to allow my jaws to relax. You may be cutting it close.
![Image](http://tickers.TickerFactory.com/ezt/d/4;10100;0/st/20050623/e/I+got+braced%21/dt/1/k/c577/event.png)
Braced on 6/23/05 for 12-16 months with top and bottom Damon 3s for moderate crowding, slight class II bite and TMJ.
Hey MuleNag,
I got braced top and bottom yesterday. My appointment was at 1.50pm and i was home by 3pm. That included getting my front teeth reshaped and the talk about how to take care of my braces too. I think the actual time putting them on was about 35 - 45 mins (not too sure as i almost fell asleep lol) then 15 mins for the work on my front teeth. I only have 2 molar bands on at the top, the other two molars on the bottom, have had the hooks bonded on.. (I don't know if that is just me or everyone has this done?) so my ortho didn't have to spend long trying to find the correct bands. But as people have been saying it does depend on your treatment and your ortho, but if you are going both top and bottom metals tomorrow then it will more than likely be done in about 45 mins. Good Luck...let us know how it goes![Very Happy :D](./images/smilies/icon_biggrin.gif)
It took over two hours when i got my braces put on. I have ceramic uppers and metal lowers. But the assistant and the ortho seemed really busy that day so i think that's part of why. It took a long time as some of the others said to find molar bands to fit. I have 4 and she just said it seemed my teeth were small for an adult. I think it all depends on the ortho, assistant, and your situation. Good luck! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
I'm braced!! They got done in 1 hr 10 mins. I easily made it to my other appt! *whew* Thanks for all the input!!
I can see how it could have taken longer...I only have brackets on my eye teeth and back...nothing on the front four, top and bottom...so if those would have been done I think I might have missed my other appt!
