I have metal brackets upper and lower, (have no idea what kind) with ligatures on every teeth with the exception of the last tooth on each side.The last tooth has some sort of tunnel in which the archwire slides through. It is not locked place, it just slides.
My archwire has been constantly popping out and digging me in the cheek almost every day.
I initally went back to the ortho, and they fixed them for me. They explained that I had a "baby" flexible archwire that would later be replaced with a thicker, less-flexible kind. She showed me how to pop it back in, so that was nice of her.
BUT because I had two of my molars previoulsy extraceted, I can only bite on the very back molars, and the wire which hangs over the extraction sites. I think the pressure of my semi-soft foods is popping it out- very, very annoying!
![Confused :?](./images/smilies/icon_confused.gif)
Anyone else have this problem- I'm playing with this darn wire so much that today it bent almost in half! Advice?
