Also new
carzfrm60s
Also new
#1 Post by carzfrm60s »
I am a 46 yo male and have braces for my third time.Twice in my 30s.First time for 2 years,then again about a year later due to relapse.This time mostly due to lower front tooth that just won't stay put! Have 8 clear brackets on top & 8 metal on bottom.Dr.says 10-12 months, will be some form of elastics at some point.This time he will use permanant retainer on bottom,not sure about top.
carzfrm60s
#2 Post by carzfrm60s »
Not sure I'd call it dedication or fear of long term problems,but am glad ? to hear Dr is going to try perm retainer. Have heard and read pros & cons but just ready for teeth to stay put! Thanks for your post KK.You seem to be lots of help to everyone.
Flora2006
#3 Post by Flora2006 »
Good to hear you will have a permanent retainer. Hopefully you won't have another relapse. 3rd time in braces must be annoying...but you have to do what you have to do ;)
Good luck with you treatment and you will be out of the braces in no time. 10-12 months isn't bad at all.
Lee54
#4 Post by Lee54 »
Carzfrm60s, did you wear retainers after the previous treatments and still have relapses, or weren't you told to keep wearing them? I thought the retainers would keep things in place, but maybe not if work is done past childhood years? I'm new to this board also, older & don't have braces yet, and wondering if it's worth it all if it could relapse afterwards!
carzfrm60s
#5 Post by carzfrm60s »
Wore hawley retainers first for several years. They didn't hold bottom very well.Went back into braces for a year then did the clear retainers.About six months ago had to have 2 crows on bottom back couldn't wear retainer for about 3-4 weeks.Thats when the pesky bottom front tooth decided to show it's strength and moved forward again.Dr. tried to use a hawley to pull it back,but no go,so here we are again with braces! Hopefully with permanant retainer Third times a charm!
Kimber
#6 Post by Kimber »
Wow -- you've sure got a strong-willed tooth there! Good luck this time around!
Spacers June 1, 2006
Braces on top June 8, 2006
Braces on bottom August 21, 2006
Only two years to go!
