This pesky tooth!!!!
Just needed to vent of some steam because I'm sick of this wonky tooth!! Before I started my treatment in February this tooth wasn't wonky at all, it's been like this for about 3 months and it's really annoying me!!!!
My ortho has told me that the gap needs to be big enough before putting a bracket in this tooth. My next adjustment is on 28th July. Please tell me people that you all think i will finally be able to get the bracket on this date!!!
http://i81.photobucket.com/albums/j206/ ... e06012.jpg
(If i've done this right the image should be on the link above)
super soo, I feel your pain. I have the same problem with the same tooth and when I started my treatment my ortho told me this would be the last tooth on the wire. She also told me it should take about 3 to 4 months in order to make room for that tooth. Well I'm now on my 5 month and about to go to my 3rd adjustment and I'm almost 100% sure that there is still not enough room for that tooth . So I guess I'll try not to be to disappointed when she tells me I'll have to wait until my next adjustment to bring that tooth in , which will be about 7 months. I will be looking foward to that next adjustment to see if finally that tooth will be ready to join the part . Good luck with you wonky tooth and keep is posted as to your progress.
Got my braces off 9/20/07 after 19 months and 3 weeks. WOOOOOOHOOOOO!!
Hi,
I had a spring for quite a few months too. It is a pain but it eventually gives enough space for the tooth. I have a feelling that tooth was "wonky" before you just straightened out all the other teeth so that one is even more "wonky" than ever. Be patient. It looks like there is almost enough room already so I bet it won't be long now.
Mid Forties!
Mid Forties!
I have that same problem with the same tooth. I have two molars extracted on each side so I don't know if I will get more movement than you . I am only braced on top! I have several weeks to go before I get braced on the bottom I can't say I know exactly how you feel but you are braced on the bottom, the bottom teeth look very good except that tooth so I would be happy trust me ! I have way more crowding on the bottom. I think it really depends on the ortho because I have seen people with incisors pushed way back like yours and some orthos put brackets and archwire on those also. I just think that it's way too much pressure if there isn't enough room to bring it forward...
Gennel
Gennel
This pesky tooth - updated pic - amazing!
I'm so impressed, I finally got the unbracketed tooth bracketed yesterday and the movement already is incredible in just one day!!!
Before...
After...
http://i81.photobucket.com/albums/j206/ ... rtooth.jpg
Before...
After...
That's great movement, Super Soo. My lower right lateral is also behind the others, so your progress really makes me hopeful that mine will move to the arch quickly.
http://img424.imageshack.us/img424/6582 ... 2of.th.jpg
Jenfire
Jenfire
Ceramic Braces and RPE, estimated treatment 18 months
