I had my molar bands fitted on the bottom a week ago and I'm going back on Friday to have the lower braces put on. One of the molar bands isn't as low down on my tooth as the other one and in fact the top of it seems to be above my tooth surface on one side as I can feel the metal edge.
Is it possible for them to "slip" or did he maybe not push it far enough on in the first place? Even despite wearing spacers for a week the gap was still very small and he did say it was a struggle to get them on.
I'll mention it on Friday as I guess he can either re-position it or file it down a bit but I just wondered if anyone had ever had a band move?
Cheers
Lisa
Molar band doesn't seem to be on properly!
My molar bands werent totally flush against the teeth, but i somehow got used to it after a few days. But it is very possible the bands can be moved into a more comfortable position to you.
The bands are very easy to remove because i've even pulled one off by accident before
and ive had one removed and replaced by the ortho and all i felt was a little pressure.
![Embarassed :oops:](./images/smilies/icon_redface.gif)
![Image](http://tickers.TickerFactory.com/ezt/d/4;51;2/st/20051010/e/full+metal+braces/dt/5/k/1162/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10708;133/st/20070712/e/Debanding/dt/5/k/e0be/event.png)
oh thanks for that Angel, I was a bit worried that's all.
I'll mention it on Friday and hopefully he will be able to push it down a bit more or file the sharp bit off. You know how when you know something is there you keep poking it with your tongue? I have got a sore bit on the end of my tongue from repeatedly feeling at the sharp edge.
Why on earth do we do that I wonder?![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
let me know how it goes...
Hi Lisa65
I have a similar thing with my top right one as it sticks out off the tooth a bit and I catch my tongue on it. its not too bad but none of the other teetch feel like it. Please let me know how it goes. Im only 2 weeks in and havent got an appointment for 3 weeks now so it would be good to hear from you what they say.
Good luck with the braces, hope all goes well
x
x
Hi Waddles, I rang my ortho today because I was convinced that the band was working its way off
and he saw me as an emergency. It wasn't actually coming off but what had happened was that some of the cement had come out leaving a sharp edge.
He filed it down for me so it's not sticking up so much anymore, and he said anytime I'm worried about anything just to get in touch - so I didn't feel so silly after that! He said if I still have trouble with it he can put some more cement on.
So I would say that if your band is troubling you too much then give your ortho a ring and ask if he can file it down. It only took a couple of minutes.
