I've read about people using salt water to help with the soreness, but no one really talks about the canker sores from poking wires and sharp braces.
Wax helps until you eat, then you either eat the wax or remove it. But rinsing with hydrogen peroxide works WONDERS!!!! You can buy the expensive Peroxyl ($11 at Walgreens) or just use hydrogen peroxide watered down half+half with water. The peroxide helps to heal them quickly. Surprisingly it doesn't taste too bad, if you don't like the taste just put a small dot of toothpaste in your mouth to cover the taste.
Rinse with it for 1 minute then rinse with just plain water(use the wax for a few days to help with the pain too). I got rid of my canker sores in just three days; I normally suffer with them almost a week.
Really? I would have never thought to put hydrogen peroxide in my mouth! I'll give it a whirl though. This wax thing is no fun. It comes off all the time and my teeth are really sore so to push against them with the wax is not fun
I used 6% Hydrogen peroxide diluted with 3 parts of water as a mouth rinse when I bit my cheek the other day, and the next day it was all healed up.
It's also good if you tend to get a coated tongue. I tend to get sinusitis and therefore sometimes am a mouth breather at night if my nose is too bunged up, but if you rinse your mouth out with the HP and brush your tongue with it too, all that yucky tongue fur comes off!
It's a mild bleaching agent so may also help to remove stains from your teeth.
Luckily touch wood! I don't have to use it. Salt Water does the trick...
I'm a bit concerned about the use of Hydrogen Peroxide. I know its in small amounts but its still like bleach isn't it? Its the stuff you use in hair colourants and household cleaners..
After my surgery I noticed that there appeared to be some whitish stuff around my sutures in my mouth and I took HP and a Qtip and applied directly. Fixed it right up. I am a firm believer in HP for skin cuts and infections. I had just never tried it in my mouth. Be sure to spit the rinse out!! The bottle says it is for external use only.
Braced 5/11/05, BSSO with advancement 6/21/06, Debanded: 8/1/07. Click on www for my braces story.
Hydrogen peroxide is perfectly safe to use as a mouth rinse - if you look on the bottle, it will tell you how to dilute it to use in this manner. Of course, as with most mouth rinses, you shouldn't swallow it.
The concentration of peroxide you can purchase is different depending on where you are in the world (it's 3% here in the US), so follow the instructions on the bottle for the appropriate dilution.
Science lesson for the day: Hydrogen peroxide works through oxidation. Oxidation kills germs very effectively. Bleaching is a form of oxidation, so the terms are often used interchangeably.
Try Carmex, too... You can find it at a lot of grocery stores and pharmacies, and it's got salicylic acid to help heal and menthol to cool the pain from rubbing... plus it work wonders for lip balm. Just gotta make sure you try to pat-dry the area by the sore before rubbing it on so it sticks.
Principessa, I asked in Boots and they were out of stock although they generally have it , but I got some in Superdrug for 75p.
There is a 6% and a 12% strength available. I bought the 6% and diluted it 1:4 with water but remember if you buy the 12% one you would need to do 1:8.
Only use HP under the direction of a doctor. It damages new tissue growth in some cases and, for example, if you have a surgical wound, you are never to use HP.
I'm just curious...If HP was only meant to be used under the direction of a doctor, why would it be available without a prescription? Personally, I think it's a great product...especially when the dog decides to scratch my arm!!
Braced: Jan. 17, 2006
Removed: Oct. 26, 2006
Fixed bottom retainer
Clear Essix Retainer on top
My ortho gave me Peroxyl and it has worked wonders on sores and such. And the salt water rinses help as well. Glad you finally found something that helps.
