Just wanted to update you on my first adjustment. I went in, and the tech started to change my wires, from my first wire, to the square one. Then she said that it might be too difficult to put the new wire in the bottom arch. Apparently, it's still a little too crooked. And, she didn't want to hurt me by forcing it in. (In my chart, it said I was to get new wires upper and lower). However, I told her that I'd endure the pain, in hopes of getting a new wire. The tops were changed fairly easily. I'm not going to tell you it wasn't uncomfortable...because it was. Then on to the bottom...and, after a few attempts, she wanted to go back to my original wire. It was very uncomfortable...borderline painful. I said..."Wait....we can do this!!" We both smiled. Then I asked her if she could "hold" my teeth while she did it. Basically giving my teeth more support...and...IT WORKED!! She got the new wire in! It's a little thicker, but not so thick where anyone would notice.
Then she put these little metal "anchors" on the wire itself. She said that would prevent the wire from moving too much to the right or left.
Then, the doc came to check me. He said that I should expect quite a bit of movement with my new wire!!! And he said that he thinks I'll be able to get my bite turbo's OFF at my next appt...which is in 10 weeks. (I will have worn my bite turbo's for a total of 4.5 months, assuming they come off in 10 weeks.) Doc said that they don't like to leave the bite turbo's on too long, as they will start to cause problems...like causing teeth to start growing down further than they should. And other bite problems.
Naturally, I forgot to ask how they get these bite turbo's OFF.
Currently, my teeth ache...but not so bad I need any pain meds. I'll probably take a Tylenol before bed tonight...just to be on the safe side. The tech said they'd be pretty sore tomorrow, and to be prepared for the discomfort. I had some french fries, and a few bites of a cheeseburger for lunch, but I'm going back to pasta for dinner.
I'll try to post pics in a few days. (Thanks Gennel!!!)
Have a beautiful day, everyone!
eagle
