My ortho wants to have 3 of my 1st bicuspids extracted. I've been braced for 1 month and can't believe the movement I've already had.
Has anyone else had 1st bicuspids removed vs. 2nd bicuspids? I'm afraid of gaps because I do not have wisdom teeth. Would someone let me know of their experience?[color=darkblue][/color]
1st bicuspid - 2nd bicuspid
Braced on 6/28/2006
I had all four first premolars extracted. I still have the extraction gaps and you can only see them if I smile really big and if you look at my teeth from the side.
I recently told some friends about the extractions and they were suprised, as they have been around me for months with the extraction gaps and had never noticed them!
If you got your wisdoms out with just novocaine, you'll be fine with the premolar extractions. Best of luck!![Very Happy :D](./images/smilies/icon_biggrin.gif)
Top brackets and spacers on 2/17/06
Molar bands on 3/6/06
Extractions and full braces 3/27/06
Update: 22-24 months total time in braces!
Typically 1st premolars are extracted over 2nd because it is easier to move the anterior teeth backwards, and leaving the 1st PM will add more surface area to the movement. But if teeth are periodontally compromised, decayed, etc then sometimes the 2nd are used. Either is an acceptal treatment option in most cases, but why make things harder
Best,
Rory
Best,
Rory
