How Many Teeth?
Dramagyrl
How Many Teeth?
#1 Post by Dramagyrl »
I saw this topic a little bit in a forum before and wanted to clarify.
How many teeth are people supposed to have? Is there a specific number, or it can depend on the ortho's plan?
I've had my wisdoms and four more molars pulled. I've been told I had too small of a mouth to hold all my teeth. I'm still wondering houw the four new extraction gaps will be filled, but that will come with time. In the meantime, I have 12 teeth on the top, 12 on the bottom- 14 in total. They don't all match either, I had one canine removed in the midst of extractions, etc. But the numbers match on the top and bottom.
fitchick
#2 Post by fitchick »
Hi Dramagyrl,
I don't think there can be a certain number of teeth that we are all supposed to have. I currently have 12 on top (will be 10 after my extractions) and 11 on the bottom. I have a very small mouth and barely have enough room for those!
Interesting question. I wonder how this compares to others?
Julie
Jun06 Lower brace on
Aug06 Root Canals completed
Mar07 Upper Brace on
July08 Braces off!!!!!!!!!!!!!!!!
Lisa65
#3 Post by Lisa65 »
I have 12 top and bottom. I have large teeth and a fairly small mouth. I had my widsom teeth out at 21 and all 4 1st bicuspids out as a teen.
My ortho is hoping not to have to remove anymore teeth, he said he will shave a bit of enamel off to make space if need be.
Samantha08
#4 Post by Samantha08 »
I had all four of my wisdom teeth out, so I have 14 on top and 14 on bottom. :)
Estimated Time: 15-18 months
LP
#5 Post by LP »
I'm left with 12 on the top and 12 on the bottom after the removal of all 4 wisdom teeth and 2 bicuspids and 2 molars.
lionfish
#6 Post by lionfish »
15 upstairs and 14 downstairs, plus an impacted upper wisdom tooth sitting way up in my upper jaw. I managed to keep 2 out of three wisdom teeth.
nvcarissa
#7 Post by nvcarissa »
I started out with 16 up top and 14 below. I never had wisdom teeth in my bottom jaw...they just never developed. A dentist years ago told me I was a mutant. My upper wisdom teeth were removed at my surgery since moving my jaw forward would no longer give them any teeth to rest on. So now I have 28 teeth.
Braced 5/11/05, BSSO with advancement 6/21/06, Debanded: 8/1/07. Click on www for my braces story.
jcdamon3
#8 Post by jcdamon3 »
I have 28 teeth after the 4 wisdom teeth were extracted when I was 16.
I get to keep all my teeth because I have a huge mouth! Okay no comments.
Mid Forties!
Henna_the_braceface
#9 Post by Henna_the_braceface »
I've got 12 on top and 12 on bottom... I had 4 premolars removed.
Gennel
#10 Post by Gennel »
I have 14 on top and 12 below . I still have all my wisdom teeth and no plans for them to be extracted since they won't cause any crowding issues after I get braces off. I had 4 extractions on bottom and 2 on top.
Gennel
OneTime
#11 Post by OneTime »
I have 28 now, wisdom teeth was extracted when I was a kid.
In process...
4 spacer and upper braced 1/10
Spacer removed and fully braced 1/24
Final 05/15/08
SamanthaClavier
#12 Post by SamanthaClavier »
i have 29 (1 thats imapcted that needs to be cut put in the fueture,on top i forgot what side though.)my husband HAD 32 (8 removed.)so now he has 24?he has a BAD over bite.
Jillianleab
#13 Post by Jillianleab »
I have 28; only my wisdom teeth have been removed. One ortho I met with wanted to extract 4 teeth (made no mention of widsoms), but the ortho I went with only told me to have the wisdoms out. Funny how doctors in the same profession can have totally different opinions, huh?
~jlb~
Braced 5/19/06 - Full Metal Mouth!
Went topless 07/27/07!
Totally NAKED 08/30/07!
See my braces story with lots of pics here:
http://www.archwired.com/phpbb2/viewtop ... 2806#92806
Joanna20
#14 Post by Joanna20 »
I've got 14 in my upper jaw (soon to be 12) and 12 on my lower jaw (don't know if I'll have extractions in my lower jaw).
I think the right number depends on the size of you jaw and the size of your teeth.
Cheers,
Joanna
Next Ortho. consultations: Dec. 26 & January 16
Next Higienist consultation: February
turrrtlelove22
#15 Post by turrrtlelove22 »
I know this is a old thread, but I was just bored and browsing...But I have all 32 teeth...YAY...hopefully it will stay that way... :D
LiFe iS A HoOt iF You arE aN oWL...O.o
Sept. 28 ~ Consult with Orthodontist
Dec. 5 ~ Spacers In
Dec. 12 ~ Braces On!!!
