Waterpik users
Waterpik users
Can anybody give me any Waterpik tips to avoid turning the bathroom into Wet and Wild and oneself into a wet T-shirt contestant?
I've tried closing my lips while squirting, but can't really focus on an individual tooth that way.
Cheers
Cheers
Don't stand completely upright, but rather lean way over the sink. That will keep you from getting all wet.
Everyone covered any regular advice I would give, but I do have a tip while you are learning and practicing.
The first couple times I used my Waterpik was in the shower. I got it all filled and ready before I started the shower then brought it in so it didn't matter if I got water everywhere. It got me familiar with the feeling and sensation so it's way easier over the sink now.
![Image](http://tickers.TickerFactory.com/ezt/d/4;51;125/st/20060711/e/I+Got+Braces+On/dt/-2/k/fae0/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10727;104/st/20070725/e/My+10th+Adjustment/dt/-3/k/23ad/event.png)
The first day I used the waterpik I made the BIGGEST watermess lol
I had water everywhere on the mirror,sink and counter including myself. I thought this was some cruel joke lol. I asked the hygeniest. She told me to: Look down at the sink,close your mouth and leave a little gap open on your lower lip so the water just drips straight down. Also DO NOT look at yourself in the mirror because you will spray it everwhere. Using the waterpik you can feel each tooth and pass the waterpik over gum area of the tooth and also in between the teeth. I then do the same thing on the inside of my teeth. The hygeniest said to ONLY use the waterpik on #1 or #2 . I was like OMG Ive been using it at #3 .#4 . She said since I am wearing braces and will have so much movement and my gums will either recede or get a little loose NOT to put the speed so strong because it will lift my gums off my teeth even more. So I use it at #1 for my front teeth and #2 for my back teeth.
Make sure you have it in your mouth before turning on
Make sure you turn it off before taking it out of your mouth.
Gennel
I Love my waterpik!
Gennel
I Love my waterpik!
waterpik
Boy did i make a mess when i first used it!! I still forget to close my mouth and it goes up my nose and all over the mirror!! I am getting it slowly now....i just close my mouth and guide it over each tooth. I love my waterpik!! I wish there was such a thing as a battery operated mini one to carry....that would be awesome!!
Belated thanks for all your tips
Thanks for all your tips, I've tried each one and now do a variation depending on my mood, as they all work really.
I don't have vari-speed on my Waterpik, just off and on, but I have noticed a bit of sensitivity since using it. I do, however, have two types of tip, low pressure and high pressure. I accidently used the latter on first go. Gave myself a right shock!
PS: Lucyloop, nice to meet you. How's sunny Essex?
