Toothpaste without SLS?
rdms_girl
#1 Post by rdms_girl »
Hi everyone
:?: I am having some trouble with cankers (and only on day 2!) and was wondering if there are any brands of toothpaste without SLS that anyone might recommend
Thanks in advance :D
rsprouse
Re: Toothpaste without SLS?
#2 Post by rsprouse »
Hi everyone
Biotene and I believe Rembrandt makes a version but I am not sure on that. Biotene has a rendition that does not contain SLS for sure.
Good Luck,
Rory
jennielee81
#3 Post by jennielee81 »
I use Rembrandt Canker Sore toothpaste. I buy it at CVS and RiteAid right off the shelf. It's not with the "normal" toothpastes, it's down that isle but it's with the specialty stuff. Look hard for it or ask.
You can also order it from Drugstore.com. It has helped me IMMENSELY!!
http://www.drugstore.com/products/prod. ... T-0-SEARCH
GOOD LUCK TO YOU!!
Jenn
rdms_girl
#4 Post by rdms_girl »
Thanks for the advice - off to the drugstore I go :D
